Cjccmc
Hi all,
I have wet rotted wood under this toilet on a slab floor.
It's a bit of a long story but since I have this problem after a pro plumber set the toilet, a solution that really works may be more involved than a usual fix. Here goes ...
My circa 1980 toilet worked fine on top of engineered wood floors put under it in 2006. Then in 2013 a dehumidifier overheated the room and melted the wax ring and the first flush after that put water on the floor. We had a plumber "fix" this. About a year later (2014) I had another plumber out for reasons I don't recall and he removed and reset the toilet. The floor had those dark areas on the side ever since the wax melted so we did not think it was an ongoing leak. But after heavy use for a few days the dark patches grew and we finally became aware last week that it was not just a stain but moisture.
It's plastic, tilted, top is 3/8" above wood flooring in front, 1/16" below wood in back.
It attaches to (glued?) a 4" ID black plastic piece which may be part of the elbow just below.
No screws holding flange to anything. No wood flooring under flange.
No cracks in toilet bowl.
Here is the current state after removing the toilet and damp wood:
What do I need to do to fix this? Ongoing damage to the replaced wood flooring is the biggest impact.
Thanks in advance.
Thanks in advance.
