Tile guy made a mistake - how to fix it?
Curiousv
Tacoma WA
TIle guy did a good job accept one corner tile
As you can see in the pic - in one corner tile has more gap compared to rest of others tiles
We have not put grout yet
So should we remove the tile which is short (which is why there is bigger gap) and replace with correct size
or we should just fill the bigger gap with grout? instead removing that tile
if we just fill with grout - will it leak or will look bad?
finally if we decide to remove that tile (its completely dried with redgard and cement baker board)
aestetic only . grout joints could be 3/8 inch with correct grout. if you are happy with the appearance then its fine
wwhitney
Berkeley, CA
Leak? No bearing on that, if the redgard is properly applied, it won't leak. Look bad? That's up to you.
That will give you a chance of a leak. Usually the redgard is broken by the tile removal, and if it gets broken near the edge of the revealed area, when painting on new redgard it may be hard to tie it in properly with the existing redgard. On the other hand, if the tile comes off without breaking the redgard, no problem. And the risk is much different if it's 6" off the shower pan, vs 4' up.
Cheers, Wayne
Curiousv
Tacoma WA
The tile in question is 4 feet above the top of tub - sorry I should have mentioned that in the initial post.
Now what do you think?
bingow
Active Member
New Mexico, USA
@Curiousv if the gap is that red-tinted area in the right hand photo, you will always notice it. I'd be tempted to try an oscillating tool to remove it and replace.
Curiousv
Tacoma WA
It is not red tinted area - what you see is - redgard through this gap - we have not put grout yet. I have uploaded more pic so you have better idea.
if the grout isnt contrasting with the tile it might not look too bad . Of cource pulling tile and resetting is option
