Tankless electric water heater under counter?
Discussion in 'Tankless Water Heater Forum' started by Spoolofpipe, Oct 25, 2018.
  1. Spoolofpipe
    Spoolofpipe New Member
    Sep 5, 2018
    Austin, TX
    Are there code restrictions against mounting a tankless water heater inside a pantry or cabinet (under the counter)?
    I was planning on putting an eemax 240v water heater inside the sink cabinet or inside the back of the pantry?
    A buddy of mine (contractor) said that I needed 6'5" clear in front of the water heater according to NEC, is that right?
    The pantry isnt a typical closet style pantry, but its divided into sections, so the bottom section I want to put it in, is 30"W x 30" T x 24" D
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    According to page 4 of the manual here's an 18" clearance from the bottom, 10" from the top (28" even before accounting for the height of the unit itself), and 8" clearance requirement on both sides (16" total before accounting for the width of the waterheater.)
    So to stuff it in a 30" tall x 30" wide space the water heater would need to be no more than 2 inches tall, and no wider than 14". Without looking up the dimensions I suspect it'll be fine for width, but will absolutely never make it height-wise.
  4. Spoolofpipe
    Sep 5, 2018
    Austin, TX
    Thanks for the response!
    The one we have is an HA series, but it has similar clearances
    "Recommended Clearances: 12 inches above and below the heater 6 inches in front of and to the sides of the heater CAUTION: Combustible materials should be kept at least 24 inches away from your water heater and the hot water outlet pipe."
    So in this case would it be the install manual not NEC that drove the clearances?
  5. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Installation instructions always supersede the NEC whenever the instructions are more restrictive than code.
Similar Threads: Tankless electric
Tankless Water Heater Forum Rheem Rtex 06 tankless electric water heater Apr 30, 2021
Tankless Water Heater Forum Need info on a Point of Use Electric tankless. Jan 29, 2021
Tankless Water Heater Forum Electric tankless system too small for a hot bath. Tweak settings, upgrade, add additional unit? Dec 21, 2020
Tankless Water Heater Forum Gas or Electric Tankless? Nov 23, 2020
Tankless Water Heater Forum 120v vs 240v tankless electric water heater Jun 28, 2020
