Takagi tankless nightmare
Discussion in 'Tankless Water Heater Forum' started by turiya ananda, Jun 16, 2017.
  1. turiya ananda
    turiya ananda New Member
    Jun 16, 2017
    Oregon
  2. Master Plumber Mark
    Master Plumber Mark Sensitivity trainer and plumber of mens souls
    Feb 6, 2005
    Sensitivity trainer.. plumber of mens souls
    the answer is easy... just tear it out and install a simple tank type heater....
    Stuff likes this.
    Stuff likes this.
  4. Phil Armstrong
    Phil Armstrong New Member
    Aug 31, 2017
    United Kingdom
    Thats surprising to hear actually as they are known for being quite reliable usually. Are you having the same issues as with that other thread?
  5. scott-perry
    scott-perry New Member
    Apr 29, 2016
    California
    Takagi was designed and built originally to work in Japan, where the winters are fairly mild. This unit should never be used in areas in America North of the Mason Dixon line where winters can be harsh. The unit simply was not designed to handle incoming water temps of under 45 degrees, and will crack its heat exchanger within 5 or 10 years under such circumstances. Meanwhile, Takagi will try to wiggle out of their warranty responsibilities, by claiming that the unit wasn't delimed frequently enough.
    South of the Mason Dixon line, they work great.
  6. Ben_Z
    Ben_Z New Member
    Nov 7, 2017
    Morocco
    I had the same impression about Takagi water heaters as Phil Armstrong, although I don't like their design. But I believe that there are many devices that are not very attractive but still they are better than other nice looking ones. Takagi has several models to just generalize an experience and I guess the Takagi t-h3m-dv-n is one of the most popular ones.
  7. scott-perry
    Apr 29, 2016
    California
    Again, if you're north of the Mason-Dixon line, and your winters are harsh, beware. If you have mild winters, go for it. When I lived in Michigan, they were notorious for only lasting 8 or 10 years, and then having to be replaced due to cracked coils. Now here in California, they seem to last much much longer.
  8. scott-perry
    Apr 29, 2016
    California
    Phil Armstrong is from the UK, where winters are mild. No wonder his good luck with these heaters.
Similar Threads: Takagi tankless
Tankless Water Heater Forum Decibel rating from AO Smith/Rheem/Takagi Tankless Dec 4, 2019
Tankless Water Heater Forum T-KJR2-IN-NG takagi tankless Oct 28, 2018
Tankless Water Heater Forum Takagi T-H3J-DV-N tankless hot water heater goes cold in the middle of a shower Feb 28, 2018
Tankless Water Heater Forum Takagi tankless heater to supply in-floor hot water Dec 12, 2013
Tankless Water Heater Forum Reverse engineer Takagi tankless WH control protocol Feb 20, 2012
