KenWS
I own a home built in 1972 with a sump pump and basin in my basement floor. There are drain tiles leading to the basin which appear to go under my house; however, am not 100% positive where they run. Yesterday we had torrential rain in CT and flash flood warnings. The sump pump has to work hard on a typical rainy day so when I got home from work I went to check on it. It was making a terrible noise and not shutting off. The basin is sealed so I opened it to find grass and leaves floating in the pit. I reached down and pulled clumps of grass that were stuck to the screen on the pump. It has rained many times and I have never seen grass clippings or leaves in my basin and as far as I know the drain tiles do not come above ground at all. Additionally, I originally thought it could be backup from the discharge, but this is not possible as the discharge pipe feeds into a 4" pipe outside the house well above the soil and the 2 pipes are not physically connected (smaller just dumps into the larger). Any idea what could be causing this?
