70 psi alone would not be the cause of a hammer but IMO could be a factor if there is a problem might make it worse.
I just have a preferance for it lower If you told me it was 70 and everything was fine (no Hammer) I wouldnt have a problem with it but personaly I would need some reason to set a regulater that high.
The pressure in all the plumbing fixtures is the same so now the story is you have 75 psi at laundry. Dont know at what point anyone else would say lets try turning pressure down a bit but Im there already
Im not that big on installing arrestors but ill do what ever it takes to fix it and that includes adjusting pressure putting on aresstors , changing fill valves on toilets and sometimes tearing into walls. I try the easier and cheaper things first. also I keep an open mind to trying things that might not be very convincing but sometimes worth a try. Mostly these have been warranty calls as most people will put up with a little noise rather than pay us to rip walls apart and hourly rate to chase this down is not something people will pay .
