JustaDIYer
OK, I'm stumped...
Recently installed a Fe filter ahead of my softener and now the softener will not draw brine to regenerate.
Things I've tried so far:
- removed brine tube from control head; confirmed suction during BD cycle, reconnected
- removed brine tube from brine valve in brine tank; confirmed suction
- put the removed brine tube into a pail of water to verify it draws the water (it did)
- replaced brine valve and reconnected brine tube; no suction
- removed the brine valve assembly and confirmed float in air check floats (not stuck or anything) when under water (it did float) and could feel/hear some suction at that point
- still not drawing brine!
WHAT'S NEXT??????
Fleck 5600SXT
drains flow freely
good well pressure
cleaned injector screen
water level in brine tank is above the 'normal' line, float has shut the water off into the tank
Advice please!!!!
WHAT'S NEXT??????
Fleck 5600SXT
drains flow freely
good well pressure
Advice please!!!!
