Thank you for adding me. I've read and read, to the point that I think I know less now....
In any case, My water test results (university testing service) show that ph is 8.26, total dissolved solids are 754, total hardness CaCO3 is 180 mg/L - (11 grains per gallon), iron is .22 mg/L, manganese .024 mg/L, calcium 43.7 mg/L, magnesium 17.2 mg/L, and total alkalinity is 222.8 mg CaCO3 / L.
Real-life results are a sulphur smell and rust staining on fixtures. I have changed an anode rod, which helps short term, but is limited in efficacy. I would ideally install a system myself as I seem to understand things better when I go through the process. Cost is a factor, but I think I can afford to do this correctly. I do not have a meter, but would consider this system to be a 10 to 11 person system, depending on who is "home" at the time.
Any thoughts? Thank you for entertaining yet another "what system" question - again, I've read until I'm thoroughly confused.....
NCPABill
NCPABill
