Our softener is in our basement with all drain lines overhead. so I want to run it up about six feet to a bath room sink drain just overhead and replace the sink down pipe with one that has a 3/4 inch side pipe ,( one that is used for a dishwasher drain attachment ). Side pipe angles up some.
Can I use the sink type Airgap to hook my Softener drain to it?
Or will there be too much flow for it to handle to drain with out shooting water every where?
My Softener drain spec shows 1.6 gpm max.
Side note, there is a floor drain in the cement floor, though only the furnice A/C drain pipe goes to it and I don't trust the builder put anything more than a pit below it.
We are on city sewer and the house waste line for the entire house drops down from the floor joists and turns to exit the cement wall about 4 feet above cement floor. Thank you.
