Size of rough in valves
jess58
Hello. Need a little help here. Is a Delta 602 rough in valve without stops the same size (xy axis from center for hot/cold/shower as an R10000-UNBXHF)? I'd like to retrofit one by removal and unswerving and then just adding the new valve. Thanks in advance for any help
TJRAD
Active Member
California
The Delta R10000 rough and Moen Posi temp 2570 rough are the smallest roughs I can think of. Both are larger then your old delta rough. I think you need to prepare for some cutting and sweating. If your working from the back side this wont be an issue but if your intention is to do this from the front finished side then maybe a remodel kit would be a better option. check it out, moen TL2368ep for trim then add the 2570 rough.
good luck
