Showerhead setting creates knocking
Harrisonnate
Burlington, WA
I have a puzzle I can’t solve and am hoping not to cut into the wall, if possible. My shower has a handheld shower head with a hose and different flow settings, as they do. If I don’t turn the shower on for 10 to 12 hours I can turn it on to one particular flow setting and water flows just fine. But as soon as I change the flow setting on the showerhead, a knocking sound begins and water fizzles out to a stop. The bizarre thing is, even if I try to then turn it back to the original setting the knocking continues and there’s no water. I have to let it sit for the rest of the day before I can get water to flow freely again from that original setting. I’ve replaced the handheld shower head already hoping it was an easy fix, but no luck.
Thank you!
Tuttles Revenge
What brand/model/style is the shower control? Some showers have a pressure balancing "spool" that might be getting stuck that may prevent the flow of water.
How does the handheld hose connect? Could it be getting kinked?
Is there a vacuum breaker on the outlet? A vacuum breaker may be getting stuck (least likely)
Harrisonnate
Burlington, WA
Thanks for the reply! What I failed to notice or mention was the little adapter between the hose and the wall outlet, which I assume is a flow restrictor. As soon as I removed it the issue went away, so it must have been faulty. Appreciate the help!
Tuttles Revenge
That adapter is the check valve that prevents the possibility of dirty water being sucked back into your drinking water if the hose is left on the floor.
Neil Binda
Toronto
Sometimes it even voids the warranty if it's not installed due to water consumption laws
