shower drain & p trap code question
nc8861
North Carolina
Watching some TLC tonight on some home improvement show and this guy says that according to code, compression fittings on a shower p trap can't be used in an area where you can't get to - the example on the show was a second floor bathroom between floor joists. Is this true? Does everything have to be glue joints?
I'm in a 30 yr old house, 2nd floor bathroom - only access from 1st floor would be through the kitchen ceiling.
Jimbo
San Diego, CA
Compression fittings on tub drains have been around since long before glues pipe. I have heard that some local codes don't allow them, but in general I think you can still use them.
trap
The compression part is the inlet. The large nut is a ground joint. But regardless, I would NEVER use that trap in a concealed location. I have seen too many of them with snapped locknuts at the ground joint.
