Pat1
- Messages
- 3
- Reaction score
- 0
- Points
- 0
I am doing some repairs to a newly and cosmetically remodeled home. This house is built approd 1965, so I know the house's plumbing dates back to then and any repairs most likely would be pre-80's.
The problem I am having, is when I turn the shower off (single handle mixer with a diverter in the tub's downspout) water flows from the shower -and- the tub both. I figured the diverter would be the cause so I bought a new tob spout with built in diverter (the style that has the gate at the front end of the spout and you pull the little knob up to divert.) This did not solve the problem. Staring at it didn't cure it either.
As I stated, the faucet style is a single handle faucet, mfg is unknown as the set is rather aged, I do not yet know if it is the original set (I don't believe they had single handle mixers dating back to the 60's?.)
The only possibility after replacing the tubd downspout with a new one that has a better seal is 1) There is not enough water pressure from the well to the tub/faucet, as when -any- water use occurs (tub, toilet, sink, spigot, ect) the punp turns on, then off and continues into a constant cycling spree for some time, or, 2) It states 4 inches of copper tubing should extend past the tile, which in this application, only about 2 inches extends out, but the pipe does extend far enough into the downspout to fit past the o-ring inside the downspout's shaft. I don't think it's the latter, for as i stated, the o-ring is making a well enough seal and there is no water leak anywhere else.
I saw another thread that spoke of a valve being installed upside down, can that be done with a single handle mixer/faucet?
Any help would be greatly appreciated!
