Mark Mehlberger
I have a shower design layout that I have pretty much settled on that maximizes the area in our master bath for a custom shower enclosure. While I have a fairly fixed idea as to where the shower heads should be placed, I am having some issues determining where the valves should be placed to maximize practicality, plumbing physics, and any plumbing best practices. Here is an image of the layout with the walls lettered A-D.
Ideally, the fixed shower head will be on Wall "B" and a Handheld shower will be located on Wall "C'. I would like to place a Temperature Mixing Valve, that is preset to a temperature and always on, first in the loop, with separate volume control values down the line for each of the two shower heads. Also Ideal would be the control valve for the fixed shower head be placed within reach of the door on either wall "A" or "D" to eliminate the need to reach through the shower stream to turn the head off and on.
One issue I have is that Wall "B" is an exterior wall. The exterior walls are 2x4 stud, leaving little room for plumbing. Even though I am in south Texas (San Antonio), we have had few winter freezes. So my thought on this wall would be to insulate and drywall (greenboard or cement) as normal and then create a "wet wall" furred immediately on the inside of the insulated wall.
The current shower that is being replaced is much smaller and has a single control valve and shower head on Wall "C".
Given all that, here are the 4 options I am considering (based on the image above, the walls are laid flat in the drawings below):
Option 1 assumes keeping the original hot and cold feed in place, while all other plumbing would be new. To get the control valve on the opposite wall requires a long run from the Mixer with the pipe snaking back and forth through the "wet wall":
Option 2 assumes moving the hot and cold feed to the opposite half wall. This creates two long runs for both shower heads, but places the controls in easy to reach position prior to entering the shower.
Option 3 is similar to option 2, but places the controls on the other half wall. Plumbing in this wall may be difficult to move the hot and cold feed, but would create shorter runs than option 2 and offer the best access to the plumbing from the back side, should there ever be an issue requiring wall removal.
Option 4 places all the plumbing in the "wet wall" created as mentioned above, and potentially reduces the runs on the feed to the shower heads, but is not practical if ever an issue arises and would require a thicker "Wet Wall" to accommodate the plumbing around the Mixer.
If you are still with me this far, and I haven't lost you with my crude drawings, I was hoping someone could advise me on what option they think would be best, or if you have a suggestion on any other design I may not have thought of.
Full disclosure: I am a very capable weekend warrior, and will not be offended if you think this is over my head, or I am just plain crazy. Even though I plan to do the work myself, I will be checking on code and inspections, but want to come in with the best plan up front to ensure I don't look half-cocked and raise unnecessary red flags.
Thanks for reading.
Mark
Thanks for reading.
Mark
