TerryR
I have seen and read through a few threads here about very similar situations, but I am already fairly far along on this process and I feel like my situation may be slightly different.
Initially, we decided to put in a bladder tank to supply the new cabin, which is installed and connected to the existing well via 1" line, after a Tee at the pump.
The main home has it's own tank, with a filtration system, pressure switch, and control box.
We have yet to hook up the secondary tank's pressure switch because that is going to take a whole other effort electrically.
Currently, since we have tied into the original line feeding the main home with a Tee, we have lost pressure in the main house, while there is a ball valve that is closed after the cabin's tank, before the cabin... so no water is actually getting to the new build, but just to the tank.
Originally there was a check valve after the pump before the 150' line to the main home, and the Tee was installed after the check valve.
There is another check valve before the new tank supplying the new cabin.
Could the location of these check valves be creating some sort of vapor lock, or pressure loss?
I have read in some of the other threads with similar situations about a CSV. Would this help my situation, and/or would I need to install one at each tank, or just one at the new tank?
I hope that this is clear enough of an explanation to any of you pros that you can provide some insight. Any help or advice would be much appreciated.
