Septic Drain Field Inspection Pipe
ainsdu01
Wisconsin
Howdy. Just dug up a root filled 30 year old leach field.
Have new pipes in their trenches and have a question about inspection pipes. Old field did not have them and guy who pumped it for me said they need them now.
Running 4 lines out of a d box. Can I put a 90* at the end of the pipes and then run a 3 ft piece of solid pipe up past ground level with the screw on caps? Or do I need to cap pipes underground and then set an inspection pipe in each trench?
My thinking is if I do the 90* it could also act as a clean out on each line if needed. I would also be able to see if water in lines and not just how fleid is draining.
