Need some advice please. Cant make up my mind what micron filter I need .
Getting ready to install a Pentex water filter that has a 4.5" x 20" filter.
This is a small 2 bed rental property I own. Have owned 15 years and seems to be a very good well. Never runs dry even in drought conditions. Water very clear to the eye and taste good. No trace of any smell or iron stains on fixtures.
No problems for 15 years. Except I do notice faucet aerators clog and I can or replace about every 2 years.
Pex with brass fittings installed 15 years ago. Have had just two pex fitting corrode 2 years ago. These also were a off brand fitting. I was going to replace all of the brass pex fitting with the poloy ones. But inspected a few others and they seem to look fine. Of course will use the poloy ones on any new fittings I need.
My question is what micron size filter should I use. 20, 30, or 50 microns?
For less maintenance I am looking to only have to change the filter every 1 or 2 years.
Has been fine with no complaints for 15 years. But I consider this a cheap upgrade. And assume it will take care of aerators clogging. I maybe might help the brass pex fittings.
Appreciate any advice.
Thanks
Thanks
