Samuel Newman
Hi all,
I am a general contractor here in Vermont. I have a question about serving two buildings with one well and pressure tank. We are building a house for our customer; it is the second house on the property and the goal is to supply water to both houses from one tank (if possible).
We have redone the plumbing so that it goes from the well to the original house (about 20 feet of 1" poly pipe), which is where the new pressure tank is. Then, coming out of the tank we have a tee and (1) 1" line serving the old house and (1) 1" line serving the new house. The new house is about 300' feet away with a slight downhill slope from the tank to the new house. Water pressure at the old house is great, but we just turned the water on to the new house, and the pressure is really weak, barely more than a dribble. I assume that this must be because of losses over that long (300') run of pipe. Is that correct? If so (or if not), what is the fix?
I don't have exact specs for the well but it is a drilled well and is prolific (well over 10 gpm).
Thanks very much for your help and advice,
Sam
Sam
