Sebring, Florida Well and Pump advise (newbie) (Central Florida)
SebringFL
Sebring, FL
Hello everyone, first time user, in my 50's and I am very excited to hear what you guys recommend.
Got a small quarter acre property outside Sebring, Florida. I would like to look into getting well water from the property.
The thought was to drive the STAR Water Systems Steel Well Point into the ground, not sure how far into he ground yet and nothing has been bought, so it can easily be changed upon advise from this forum.
Then attach a pump to the system. 12v solar pump.
The water would be piped into a water well sulfur aerator system (160 gallon tank)
Next step would be to add a small water filtration system, but, I believe prior to that, in between the sulfur aerator system and the water filtration system, there should be another pump???
The water would then go into an outside solar heater with an outdoor shower.
Are the different steps in the right order, am I missing anything?
How does the well pump know how to shut off and turn on?
Also, I see some system with a pressurized thank. What does that do to your system?
And THANK YOU in advance for your help!
When filling a tank, the well pump would be controlled by a float switch in the tank.
Regarding what works best for drawing water in your area, consider chatting with neighbors, especially any that have been there for a long time.
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
SebringFL
Sebring, FL
Interesting, so the well pump would be controlled by a float switch in the tank, very nice to know, thank you! I guess the order is
well -> pump -> pressure tank kit -> sulfur aerator system -> water filtration system -> clean water...
How does that lineup sound like?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
SebringFL
Sebring, FL
Wauw! Very nice, thank you. Is it still okay to mount a water filtration system after the PK1A Pressure Tank Kit?
The pump is not going to be submerged, my thought was to dig down two feet and put a round 3 ft. tall plastic enclosure around it with a lid.
SebringFL
Sebring, FL
Looks good. What would you recommend, PVC pipes or copper? I have been buying copper pipes for a while, so I have some.
