greg hornung
In Sept. of 2015 my sons and I drove an 1.25"x 36" sand point to a depth of appx. 22'. I have water at 14' and 8' of water in the well pipe, I thought I was doing pretty good for Northwestern Wisconsin. I installed a 1/2 hp shallow well pump with a 7 gal pressure tank there is also a 27 gal electric water heater.Now my situation is this, I primed the pump and ran it, it pulls up water and I'm getting air bubbles (big ones) and I can feel the check valve snapping shut. Now my questions, is my pump trying to pull up more water than the well can supply, and should I run the pump until the system is fully
"charged" and see if the pump loses prime and because the well can't produce enough water is it possible to pull in air at the point?
When we drove the well I used 5' sections of 1.25" galv pipe with drive couplings because of the height limit of the cieling in the garage of my hunting cabin. I noticed when we were driving the pipe the pipe nipple with the drive cap would loosen. Is it possible that one of the drive couplings loosend below ground level even though we re-tightend prior section of pipe and couplings?I also used teflon tape instead of pipe dope, will that make a difference? It seems odd that I have 8' of water in the well pipe and I have a 3' sand point and 5' section of pipe= 8', could it be leaking at the 2nd coupling?
Last question, i understand that a shallow well pump will only work to 25' now is that depth refering to the total depth of the well pipe or to the water level depth? If I drive the point down another 5' and I get 13' of water in the well pipe and the total depth of the well is 27' will my 1/2 hp pump be able to draw up that amount of water?
Any advice would be greatly appreciated, I REALLY DON'T WANT TO HAVE TO PULL MY WELL IF POSSIBLE!
