I purchased a BrassCraft (T170) Tub Drain Remover.
The large end does not fit the drain opening.
The small end that fits is 1 3/8" inch at its widest point.
The nubs inside the drain only project 1/8" +. With a 1 5/8" ID that leaves about 1/32" of bearing on each side.
I'm concerned that the poor overlap will shear off one of the nubs and then I will be in the position of having to cut this drain out.
Should I be concerned?
Is there a tool with a better fit?
I see Terry put a picture up in another post for something that no longer Linkes.
I did some tracking and came up with this:
http://www.azpartsmaster.com/Products/The-Drain-Key-Tub-Drain-Removal-Tool__PAS4500.aspx
Is that my next best (only) option?
