GoldenDaze
Re: Rheem Model #XE50M06ST45U1
Three years new; drained for the first time yesterday and replaced the plastic drain valve with a brass full port valve (original valve plugged up). Noticed no/limited water flow to 3 faucets so I cleaned aerators. Still no flow to kitchen faucet so I removed both ends of supply lines and noticed debris as I looked down the hot water supply *valve*. Can not blow air easily through hot water supply "line" but can through the cold water line. Took a piece of ½" irrigation flex line, slightly nipped end and worked it over the outlet of hot supply valve and purged into a blue bucket. The city says since the water is virtually clear at the main shutoff pipe, this is caused by something in my house/hot water heater.
