Resin smell?
Wojo42
Mi
We just installed our fleck system and it seems to be working well. No more iron smell and the staining in the shower and toilet has stopped. Bad news is I'm starting to get a smell in the water. Wife says it smells like cabbage, I just think it smells like crap.
I read somewhere on here there was a bad batch of resin that led to a bad smell, so that's the first thing that popped into my head. Second is maybe we are getting something bad in the water. Going to head to the local water softener store to see what type of test kits they have to retest again to make sure it's not that.
Could it be the resin, and should I replace it, or should I wait till after I get a water test back?
Wojo42
Mi
Took a visit to the local water store and was told that there may be a possible chemical reaction taking place in the hot water tank with the anode rod and should remove this.
DonL
Houston, TX
You should give it time.
I would change the anode with a better one. Not just remove it.
I know people remove them, But not that great of a idea.
Is the smell in your hot water only ?
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Are you sure a softener is adequate for the level of iron present? Generally when it is noticeable enough to smell, an iron filter would be used before the softener. While a softener can and will remove a small amount of iron, larger amounts may quickly foul the resin.
That said, did you sanitize the system after installing? One can contaminate the system with bacteria that then establishes itself in flex supply lines and water heaters.
Wojo42
Mi
Welp I ran the cold water for a bit and took a sniff and you could smell it in there as well so I doubt it's the hot water rod. Weird thing is the smell only lasts for only a few seconds once put into a cup. Then you couldnt smell it anymore.
Our iron when tested last year was at .69 mg/L
We just purchased a fleck 7000 w/ 48000 grain and installed it last week.
We did not sanitize the system after install. I'll have to do some research to see how to do that.
How deep is the well? Any black colors in the toilet tank, or only rust red?
Does it smell a little like decomposing leaves?
Regarding the smell possibly being from the softener, your outside hose taps probably do not go through the softener.
DonL
Houston, TX
No kidding, I've got that thing memorized by now.
The sanitation method may be in another language. But it should be in the manual.
Did You get instructions on how to do it ?
Sounds like you have Iron Bactria , but I am no expert. I think LL hit the nail on the head.
Wojo42
Mi
Unless the install process is something different from sanitation process, no I didn't do it. I followed the manual on install and start up to a T.
Wojo42
Mi
We do get a decomposing smell, but it doesn't happen all the time. I'm not sure how deep the well is since it wasn't written on our inspection, but they did mark down the well cap was damaged. (Could cause iron bacteria to infiltrate)
Only have gotten red stains. Checked the back of the toilet and it has the red stains, but seemed to be a little slippery.
How far out of the ground is the top of your casing?
The bacteria you would worry about with a damaged well cap would not be iron-reducing bacteria but bacteria that live at the surface.
Wojo42
Mi
About a foot and a half.
DonL
Houston, TX
It may be a lot not to worry about.
That is French for all may be good.
What makes you sick makes you stronger. That is a Fact, correct me if I am wrong.
LLigetfa
NW Ontario, Canada
As I said, bacteria can establish in the rubber or plastic flexible supply hoses and the symptom is as you describe, a smell on first use that then diminishes. I have had that happen after working on my system and not shocking it afterwards.
The bacteria can come from the well but it can also be on your hands and transferred when handling the plumbing fittings.
DonL
Houston, TX
lol, I missed the last line of your post. :)
We were on the same page.
Last time I installed a softener it took a month to work properly, on a once a week rejuvenation.
Smells come and go for a bit.
