steppinthrax
I currently have a Fleck 5600SXT 48K. I have around 10 - 11 grains of hardness and about .3ppm of iron. I have about 4 people in the household. I've been running a full year now on the same load of salt and for the first time the salt is low enough that I'm seeing water. My concern is since I have iron that I should maybe do a resin bed cleaning after about a year or so. I understand you guys generally use Citric Acid. Home depot sells a product call out that you put into your salt basin it is pretty much citric acid. I figure it would probably be best to install some sort of automatic feeder.
How much should I put into the basin right now. I imagine the amounts will be very different based on the concentration of citric acid etc? I have a 48K system with .3ppm of iron.
Also is this product good?
https://www.homedepot.com/p/Filter-Mate-24-oz-Softener-Cleaner-Powder-TO06N/300091047
I figure it would be cheaper to buy citric acid from ebay.
Also what's a good automatic feeder?
