G' Day All,
I have used this forum a couple times to get advice on water pressure tank and now want to just know if I can use a 45 degree elbow (pvc) to rotate the way a new tank would be oriented in my system. The current tank is 32 gallons and I want to put in a 50 gallon but the diameter of the bigger tank makes it impossible to fit it into the corner with a straight pipe run like I have now.
I can cut the PVC and connect after the valve and union (red line drawn in photo) and fit the wider tank (black circle line drawn not to scale in photo) with water feed oriented toward 10 o'clock (yellow arrow drawn in photo).
The PVC is one inch and the new angled pipe would need to be about 9 inches long from the elbow into the pressure tank. 40/60 switch and new tank is pre charged to 38. I put a couple other pictures in to show situation. Will this work or am I missing something?
Thanks for your advice
