Replacing obsolete Laing UCT 909 Recirc pump
Discussion in 'Tankless Water Heater Forum' started by mnschu, Apr 24, 2021.
  1. mnschu
    mnschu New Member
    Apr 24, 2021
    San Jose,ca
    I am looking for advice on replacing a Laing UCT 909 recirc pump used with a tankless water heater.
    Specs here: https://documentlibrary.xylemapplie...37.796466221.1619321512-1842542238.1619321512
    Amazon link here: https://www.amazon.com/laing-uct-909-tankless-ultacirc-recirc/dp/b001289v22
    It has the following problems:
    • If the pump is not running, hot water only works at the closest outlet. All other outlets have cold or lukewarm water
      • Believe the check valve is bad
    • The temperature sensor does not seem to work, the pump always run even when hot water is present and the pipes are hot
    • This pump has a timer, and I can only get hot water when the timer turns on the pump, then the pump will run continuously, even when water gets hot
      • So I really need to run the pump at all possible times
    • A few years back one of the impellers broke. I opened it up and removed the broken pieces, so it has been running at lower efficiency ever since
    I would like to replace this pump as it seems it is coming to the end of its life.
    However, it is obsolete and no longer manufactured.
    Can someone recommend a replacement pump that would be an easy retrofit?
    Thanks,
  2. fitter30
    fitter30 Well-Known Member
    Feb 2, 2020
    Retired service tech
    Peace valley missouri
  4. lifespeed
    lifespeed Member
    Apr 27, 2007
    California
  5. David Zeidman
    David Zeidman New Member
    Jul 11, 2021
    Belmont
    Hi, I have 2 Laing UTC-909 brand new in stock. I am local in Belmont.
Similar Threads: Replacing obsolete
Tankless Water Heater Forum Replacing 2 conventional water tanks with Navien NPE-240a Apr 12, 2021
Tankless Water Heater Forum Need help replacing tank gas water heater with tankless Oct 15, 2018
Tankless Water Heater Forum Options for replacing an existing Navien Feb 5, 2018
Tankless Water Heater Forum Replacing 3 tanks to tankless Jun 21, 2017
Tankless Water Heater Forum Removing and Replacing the cold water inlet plug and filter Jun 6, 2017
