cant get pilot to light or hold? You may just have to crack the union and bleed out air
Can't get it to light.
There was an leak at the meter behind my shop several months ago, and the gas company shut it off and tagged it until they repaired it. They turned the gas back on but I didn't attempt to light the boiler until this week when the weather got colder (actually forgot about it), and I can't get a pilot flame now.
I followed the instructions and turned the valve to the off position for 5 minutes (then a couple of hours) before putting it into the pilot light position. The red pilot start button does depress, but there is no gas to ignite pilot flame. I removed the entire pilot tube from the valve in case there was an obstruction at the pilot orifice, but I can't it to light on the top of the valve at the pilot tube fitting either. Well, I can get a *tiny* flame that quickly peters out even when holding the pilot button.
Tell me more about cracking the union to bleed out air. There is about 20' of pipe between the meter and the valve. Are you referring to the union on the inlet pipe? I'm more of an oil burner guy and I know about bleeding the oil pump. My knowledge on gas is pretty much limited to replacing the thermocouple every 5 years or so and not feeding my brother chili...
Thanks.
John
Edit: According to the .pdf from Honeywell, there is an inlet pressure port right at the inlet connection that's capped by a hex nut. Is it a good or bad idea to crack this open to purge air?
Second Edit: Throwing caution into the wind, I closed the remote shutoff valve on the gas pipe on the side of the boiler and removed the port pressure cap on the Honeywell valve. When I turned the shutoff valve back on, there was no gas coming out of the inlet port of the Honeywell valve, so I guess the gas company has a problem. Waiting to hear back from them.
