wjc4
Hi All,
I recently purchased my first home and have slowly been updating it to this decade. My next project is to deal with the existing 1-1/4" monoflo hot water heating system, but I have almost no experience in the design of a hot water heating system. The house is currently all on one zone and almost every monoflo tee in the system is leaking and are severely corroded (the water we have was extremely hard but I have already installed a water softener). The exiting loop is also not very conveniently placed and required a box out to be put around it all around the perimeter of the house and with the floor to underside of joists only 7'6" putting that box out back is not ideal.
The plan is to make a 2 zone system (upstairs and downstairs) while reutilizing as much of the existing system as possible. I have a ton of 1/2" pex that was given to me so I want to use it in place of the existing 1-1/4" copper pipe loop. This way I can tuck it between the joists and save head room. I know 1/2" pex isnt ideal for hot water heating systems but I am planning on running separate supply lines to each section of baseboard to help mitigate the fact that I'm using 1/2" pex. Each supply run isnt that far either (about 30' at the longest) which Im hoping will help. The house also has a small wood stove and vents in the second floor to allow heat from downstairs to make its way upstairs and heat the upper floor.
I have attached a photo of my plan and am looking for some advice on whether my existing circulator pump, expansion tank, etc are adequately sized for the new system they will be supplying and any other general advice on the design.
Thanks in advance!
Thanks in advance!
