Have an old 1908 cabin 2nd floor bathroom with an existing Chrome S Trap 1-1/4” bathroom sink drain assembly just removed. Also has a 1-1/4” floor waste hole the old S Trap fits into. Problem is the sink drain tube only has about 1.5 inch spacing straight ahead directly in front of the 1-1/4” drain hole assembly on the floor beside the outside wall. Also both pipes line up side by side each other with no gap in between as if standing beside each other. Reading this forum and want to put in a AAV and 1.5" P Trap tubular slip joint kit pointed away from the wall to create some distance but then the vertical waste tube no longer lines up with the horizontal trap tube with out an additional bend(s). How would you fix this, or make it easier? Attached an example picture of what i would like to do along with my current situation dry fitted PVC S trap.
