Replace bathroom sink drain pipe
Zoman
Maryland
Hello,
I am replacing my bathroom vanity. After removing the old vanity I replaced the shutoff valves and while removing the p trap found the drain pipe coming from the wall was corroded. While taking it apart the drain pipe coming from the wall basically ripped apart. How do I replace this? It appears to be 1 1/2 inch chrome. I'm guessing I'll have to tear out the wall to get to the connection. Thanks
Clear out the area at the base of the broken pipe that you see. We hope you will find there is a nut there. If there is, you should be able to unscrew the old stuff and put on a new trap adapter.
Zoman
Maryland
Ok, so I'll open the wall and hope for a slip nut. I cleaned the pipe off and the copper is in pretty good shape. Would it be ok to cut off a half inch to make it flush then use a shielded fernco connector to attach the new ptrap to avoid opening the wall or if there is no slip nut? Thanks for the help with this!
You would be connecting to a piece that could deteriorate inside your coupling and THEN you would finally have to remove it. Do it NOW, and avoid the hassle later. but, by enlarging the photo, it looks like a brass trap tube soldered into a copper stub. Heat the stub, pull the piece out, the go to a hardware store and buy a male brass trap adapter. Slip it on to the copper, solder it to the copper, then slide your new trap in and connect it with the slip nut.
WE need a better picture, but the one I am looking at appears to be a COPPER stub with the trap soldered into it. which changes how to remove it and ALSO how to replace it.
