remodeling bathroom and have some questions
Beamar
Chicago, IL
I doubt any code allows wet venting between floors. UPC does not.
I am aware of this. But there is not much I can do about it. I am sure there are TONS of things in this house that no longer meet code. There isn't much I can do short of tearing it down and starting fresh....
Cacher_Chick
Test, Don't Guess!
This is why you want the plumbing/building inspector involved ASAP. They can tell you what they will allow and not allow despite the current code.
If you try to do it without their approval, they can pull your occupancy permit and NO ONE will be ALLOWED TO LIVE IN THE HOUSE until it is brought up to code.l
Beamar
Chicago, IL
Well I have most of the demo done.
What I am thinking of doing to fix my main stack code problem is to add some wood to the current 2x4 construction behind the toilet. One I bump it out to 2x6, I will use 2 45* PVC pipes to move the stack into the wall then run it strait up out of the roof. Once the stack is above the ceiling I will tie in the vents for the shower and sink.
Due to the fact I will have to bump the wall out, I will lose my 12" rough in for the toilet. So I will just install a 10" toilet.
ATM, this seems to be the easiest fix for all my stack/vent issues.
Anyone see any problems with this?
