Reducing faucet hole/opening
Bratan
New York
I'm installing RO system faucet into stainless steel sink. Faucet requires 1/2" opening to be cut, but I already have 1.5" inch hole where old hose used to be. Hole is directly in the stainless sink, just bare metal no counter-top is involved.
Is there any way I can "reduce" this hole to fit new faucet? Do they sell some kind of reducer rings flange or "washer" for this. Doesn't have to be anything great look, it's an old sink... I jut didn't want to drill new hole since I have this one :)
Dj2
California
I would try a couple of nice looking stainless steel large washers with a 1/2" hole in the center.
Place one washer on top of the sink hole, then put the faucet in, place the second washer under the sink and the locking nut...voila.
You may need a helper to hold the faucet while you are working under the sink.
They have RO faucets available with a big enough trim to cover your hole. Some of these have a built-in air gap. But that would cost more than a washer.
http://www.homedepot.com/p/Everbilt...eel-Fender-Washer-2-per-Pack-800541/204284504 would have a hole that would be a little over 1/2 inch and an OD of 2 inches. The picture is not the actual washer if I interpret this correctly. A fender washer has a bigger OD than a regular flat washer.
http://www.homedepot.com/p/Everbilt-0-375-in-IPS-Flange-C1831C/205153826 would have a 0.675" inch hole. If you look around for cheap escutcheons, you may find something that looks nice for the top.
Craigpump
You can get stainless steel washers at Fastenal, they shine up nice with a little metal polish.
Bratan
New York
Just because an R/O faucet "needs" a 1/2" hole, the faucet flange is usually much wider to cover most sink holes.
Thank you all! Yes flange was actually large enough to cover the hole with no issues! :)
Looks great too!
