elgato
I have a Rectorseal Clean Check Back Flow valve that needs replacement. It is basically a tube about 2' long that has the back flow flapper attached. The plastic or rubber flapper has become stiff and causes blockage. The plumbing and base assembly are 2' down under a concrete porch. Normally you would just snap on another flapper and be good for another 10 years. However, Rectorseal has discontinued the part (96981) and they are not available anywhere. They have redesigned the product and the new parts are not compatible. Hard to believe that an aftermarket one is not available.
Any Suggestions?
Thank You
Any Suggestions?
Thank You
