On a new house construction, we have rainwater coming into the basement where the sewer pipe exits the concrete wall to the septic system. The plumber said he had to jackhammer the hole that the excavator had put in to make it larger in order to get a bigger fitting in there. The PVC elbow is partially cemented into the wall. Should the elbow joint be partially hidden, as it appears to be, in the concrete wall? And does the bend in this drain line look too tight? We are wondering why it is leaking and if the plumbing has been done correctly or not.
Here are two images:
[drive.google.com]
[drive.google.com]
[drive.google.com]
[drive.google.com]
