radiator won't heat up
fast pasquale
hardwood flooring contractor
cleveland, ohio
I removed my radiator (one pipe system) in the bathroom as I remodled it. When i put it back it no longer gets hot. Wondering what went wrong. Im aware that it should be pitched toward the pipe.. which it is. The pipe isn't warm at all... any ideas?? thanks so much
Plumber1
Florida
You must have a vent on the end of the rad. It's one that vents to atmosphere and draws air when the steam pressure stops to allow condensate to drain back.........
fast pasquale
cleveland, ohio
yes. It has a vent. I took it off and....um.. man it's been a while. I either soaked it in vinegar over nite... or i may have boiled it.. not sure... but i was given the advice to check the vent from a plumber friend of mine a few months ago. i reapplied pipe dope and put it back on. still doesn't work.
fast pasquale
cleveland, ohio
umm... well ...uh... ok...Don't laugh.... The handle had broke off years ago.... but i was still able to manipulate the screw that was left there. I had opened (turned) the screw and assumed that this was opening the valve.. it wasn't. i took some slip joint pliers to the piece that the screw was attached to an opened it up.. THIS actually controlled the valve. The pipe got hot instantly and started to fill up the radiator.. AHHHH... nice warm bathroom when it's 2 degrees outside.. I know.. I know... Hey.. I refinish hardwood floors for a living... Plumbing is something i do to save $....hehe...
fast pasquale
cleveland, ohio
now i have a small leak... i was using pipe dope (teflon paste).. is this good enough.. I know some use rector seal.. what would you guys recommend?
