I'm in the process of re-finishing my basement, and so I have access to underneath the entire first floor (but not the second floor). Now that the ceiling is open, I've found a few places where the copper supply piping is corroded (likely from mouse urine) and where there are old gate valves that are seeping very slightly. In addition, many of the supply piping is run underneath the bottom of the floor joists, which requires framing out around them. I'm thinking it might make sense to replace the piping in the basement with PEX, which would also allow it to be configured in a manifold setup. Having not worked with PEX before, I have a couple of questions:
-- Can I run PEX up to the point where the supply goes up through the floor above and then transition into the existing copper piping running to the fixtures? Or is there some disadvantage to a distribution system consisting of PEX tied into runs of copper that might range anywhere to a few feet (for first floor fixtures) to over 10 feet (for piping feeding second floor fixtures)?
-- Assuming that plan works, can I transition to the existing copper a few inches below the first-floor subfloor? If so, are there any tips for safely soldering the fitting onto a pipe that runs up into a wood subfloor? I'm not experienced at all at sweating copper so I'm a little nervous working up in the joist bays.
Thanks in advance.
Thanks in advance.
