Questions about grinder pump for new construction
Prospect62
Marcy, New York
Hello all,
I am a new guy here and a new guy to plumbing and DIY. I really don't know ANYTHING about anything as far as that is concerned, although I have been a homeowner for 8 years. I'm in public safety and have never been much of a DIY'er, but I do know my way around an automobile. There's my intro, on to my question...
My wife and I are building a modular home (2300 sq/ft, 3 bedroom, 2 1/2 bath). We have a plot of land about 1.5 acres in size in a typical environment here in Central New York State (kind of wet, kind of snowy). Our plot is situated so that the home will be located about 175 feet off the road, and (here's the kicker) the area where the basement will be dug lies about 6 feet below street level. The way the land grades, it slopes DOWN from the road to where the house will be. Obvious concerns include the sewer line, among other things. I have had two excavators/sewer guys at the site to evaluate the situation. I have been told it CAN be done, but I will need a grinder pump to eject the sewage from the home to the public sewer line (typical gravity system) at the street and given the slope, this will be the ONLY way a home can be built here. My "water in the basement" and drainage concerns are being addressed and can be discussed another day...
OK - so I need a grinder pump. I've only known grinder pumps for use in recreational basement bathrooms where gravity is an issue for occasional use. I've never heard of a grinder pump being used for everyday load of a 4 person family (dishwashing, laundry, showers, etc.). Are grinder pumps a reliable solution here? Are they that durable? I have terrible fears of grinder pump failure leading to awful sewage backups every couple years. Will someone tell me what my excavators are suggesting? Will this work?
I have been on YouTube and have learned a little about residential grinder pumps like the "E-1" systems and others. I still have concerns and was wondering if this is a common solution to new constructions where gravity won't cut it?
Thanks for any help and please, spare NO details.
Smooky
North Carolina
This type of system is done all the time, it is nothing new. There are different requirements depending on the municipality. I would contact them to see what their requirements are for your community. Here is a link to a typical set up:
http://www.aacounty.org/DPW/Utilities/grinderPumps.cfm
https://www.municode.com/library/ny...d=TITVIIPUWO_CH7-7PRILDIACAN_S7-7-5SELITAETGE
(I see your city has changed so here is info I found from this new city)
Grinder pump requirements start at the bottom of page 29 and goes down until at least page 42 in this document:
http://townofmarcy.org/content/Departments/View/11:field=documents;/content/Documents/File/169.pdf
I think you will want a battery powered alarm for indicating that the sump pit level is higher than normal. That will tell you to stop flushing etc if there is a failure.
This might be an additional point to consider if you were considering a natural gas powered whole house generator. At least run the gas line with enough capacity if you want to add that later.
Zoeller makes good grinder pumps. http://www.zoellerpumps.com/en-ea/category/1-grinder-pumps
There should usually be a 2 inch vent pipe to the roof from the sealed sewer pit.
Prospect62
Marcy, New York
Well I feel a little better about it. My Town sent me a document outlining the sewer system in place. Looks like one of the mains is 18 feet deep where it connects to a "drop manhole" and then is 6 feet deep on the other side of that (the side where I'm building). Does this thing look greek to anyone but me? Our site is located where the area is highlighted.
