I don’t know the pressure from the street. The old prv leak was a hairline crack in the casing. Supposedly this new model has a feature to compensate for expansion according to the spec sheet. I will see if I can fix up a bypass. Thanks
Bypass Feature
This regulator has a built-in thermal expansion bypass feature. This feature prevents downstream pressure from rising to more than 10 psi (69 kPa) above the supply pressure.
NOTICE
The Bypass feature will not prevent the pressure relief valve from opening on the hot
Bypass Feature
NOTICE
