Brad Anesi
DPDISXR4Ti
Investigating a problem with my Dad's water heater (DHW only). Even after moving the thermostat to "Low", and then "Vac", and then finally to "Pilot", the water was still too hot. Note, this was done over the course of three weeks - I realize the water is not going to drop in temperature immediately. As a test, I finally turned it to "Off" and only then did I get room temperature water after two days.
Am I correct in assuming the Honeywell thermostat needs to be replaced? Any other tests I should do to verify? The light flashes suggest everything is fine.
Where do find a part# on this thing?
