Problems with leaking thermostatic shower
Jaygrohe
PA
I have a shower faucet that is leaking do not know how to remove it
Marlinman
Jacksonville Florida
This is a Phylrich thermostatic shower valve. From the looks it is a 1st generation that used a Grohe cartridge. You remove the handle loosening set screws at the base of the handle. To remove the escutcheon plate you will need to locate a very small hole on the underside. Original screw is very small for flat head screw. You should be able to expose the rough valve. It does have service stops to isolate this valve without turning the water off to the house.
Jaygrohe
PA
Do you have instructions how to isolate this valve without turning the water off. Also, what cartridge # do we need to replace with?
Jaygrohe
PA
Thanks a lot for the reply
Marlinman
The valve you have is a 34419 using 47025 cartridge. The isolation valves are the outermost valves that take a allen wrench to turn. Hopefully you will be able to see my attachments. The trim shows screws holding the escutcheon on. They used both ways for the trim. If when you remove the trim and the valve looks like this it is a 2nd generation valve #34Therm_001 using cartridge # ZIPXCART.
  • [Untitled] (50).pdf
  • [Untitled] (51).pdf
Jaygrohe
PA
thanks a lot this helps. I think its first generation valve when we opened it looks like this
Marlinman
This valve is Grohe 34092. I would investigate the stops and check valves to determine if the green oxidation is due to a current leak. The main thermostatic cartridge is 47301. 1 piece not shown is a green cap ( #08060)connecting the cartridge to the handle. They will occasionally crack.
  • [Untitled] (53).pdf
