Irishjedi
I have Prestige Triangle Tube Excellence boiler hanging on the wall. It is reading "Low water pressure has fallen below 10 psi. Boiler will automatically reset once water pressure returns to normal'. However, according to the psi gauge on the front of the boiler the psi is at 20. I did change out the relief valve a couple days ago because it was leaking. Also, I did shut off the unit and turn it back on to see if it would reset, to no avail. Usually a little pull on the expansion tank valve will set it straight and increase the pressure but I was already above 10 so I didn't. Any thoughts on what could be causing this? The unit is about 4-5 years old.
Thanks,
Jon
Thanks,
Jon
