Tom O’Connor
I’m needing some advice on how to properly size my well pressure tank. What Information I know is I was told I have a 2 hp 240volt submersed well pump that I know produces 15 gallons a minute. Because of available space I have in this hunting cabin I was planning On using the water works 32 gallon pressure tank(HT32B) . But doing some more research I’m beginning to worry that my interior plumbing may not be adequate at 1/2 diameter PEX which I’ve just started running throughout? Because it’s only one bath and so small I was going to run everything on its own line from a 3/4 manifold. Also what size pressure switch would you recommend ? I’m obviously trying to gain as much pressure as possible for things like my shower and laundry fill . thanks in advance
