Hi all,
Hope you all can help me with my little problem. I replaced irrigation pressure tank and switch (40/60). I checked the pressure in the tank to make sure it's at 38 psi.
Here's the problem, I observed the cut off switch is above 60 and climbing closed to 80 psi and then switched off. Next day, the pressure indicator shown 60 psi, I drained the tank, pressure gauge shown 60 psi and slowly drop to 40 psi and then IMMEDIATELY to Zero and then the pressure switch on.
Is my pressure gauge faulty? I have a new one on hand and will replace.
My concerns are cut off is in the 80s psi and cut on is at zero psi while the pressure switch is 40/60 (new Square D)
Thanks for your time and I appreciate any advice you can give.
Twin
Twin
