hi all, wondering if someone can give some advice to me (a home owner trying to improve a few things around the house; a complete amateur)
i am replacing galvanized steel piping in my 1940s home. for one 'run' of galvanized steel pipe, it connects into a cast iron stack. my thought is to cut the large run of galvanized pipe and replace with 2" pvc. the run of galvanized pipe that i am replacing is through a non-load bearing wall that will be covered up (i.e. framed, drywalled, and painted).
i need to get this done as quick as possible and dont want to mess with the cast iron stack to galvanized steel connection that may be fused/corroded together. i cut the large chunk of galvanized already and looks clean inside the galvanized pipe. i can access the cast iron stack and the galvanized <--> pvc connection to the iron stack even after the wall is finished.
the inner diameter of the galvanized pipe is 1.25" (outer is 1.75"). i can't find any no-hub coupling that will fit this 1.25" ID / 1.75" OD pipe. based on pvc dimensions charts (like this: https://formufit.com/pages/pvc-pipe-size-dimensions-chart) i will need a no-hub coupling that is sized as '1.25-inch to 2-inch' but can't find that anywhere!
my options seem to be:
(1) find coupling with one end that measures ~1.75-inch in inner diameter to accept galvanized pipe and the other fits a 2" pvc. finding coupling that fits 2" ID pvc is easy. the former seems unlikely
(2) replace the entire iron stack with pvc/abs
(3) use 'flexible' fernco coupling (instead of the no-hub) and fail inspection
are there any other options that i'm not considering?
