Plumbing basement 3/4 bath
WiLucas
Wisconsin
I’m working on a basement bath installation and am a little stumped on how to run the drain lines and if I can vent the whole bath to an AAV under the sink.
I’ve 2 options mocked up, but am open to more - I’ve not yet cut the concrete. Hoping it would be okay to cross over the WC drain to avoid cutting through extra blocking for the shower walls.
James Henry
Billings, Montana.
The consensus on this forum is to install it like this.
WiLucas
Wisconsin
That makes sense (a lot more concrete to remove) and if it allows the AAV to under the sink to vent it all I can’t argue. Standard elbows for the bends under the sink or should I sweep them?
You can't cross over the drains like that if your planning on wet venting the bathroom through the lavatory.
Do you think everybody would agree that this would be prohibited? It would work great.
index.php
WiLucas
Wisconsin
Are we back to the" No vertical offsets" argument again?
It looks likes the space behind the bathroom is to remain unfinished indefinitely. So, would this one work if I used a sanitary T above the other T (instead of the elbow) and placed the AAV on top. Then ran an inch and half line from that T to the sink (a horizontal long sweep for the sink)?
wwhitney
Berkeley, CA
Wisconsin seems to have its own plumbing code, which by my reading clearly prohibits the arrangement shown:
https://docs.legis.wisconsin.gov/co...dings_and_environment/380_387/382/iii/31/13/b
That section on horizontal wet venting speaks of the lavatory and the shower/bathtub have a "common horizontal drain" and says the toilet(s) may connect to the "common horizontal drain".
That raises the question of whether that common horizontal drain could be pitched, say, 22.5 degrees, so that the shower trap arm could cross over the toilet fixture drain and both connect to the common horizontal drain.
Cheers, Wayne
WiLucas
Wisconsin
Just finished the inspection. If you’re curious I went with the wye on its back and the AAV above it. The inspector was surprised I didn’t run 2in to the sink and put the AAV under it. Apparently in Wisconsin an offset wet vent is okay.
