Plumbing a pressure relief valve
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by banjo bud, Oct 13, 2018 at 3:48 PM.
  1. banjo bud
    banjo bud Member
    Sep 24, 2018
    South Carolina
    i know the best way plumb one is to run the output into a drain or outside. Neither of those will be easy in any way in my situation. I’m thinking if they blow, (and what are the chances?) there can’t be that much water spewed out before it closes again. So I’m wondering if I can just route the output to a convenient spot in my crawl space. Or into a permanently placed bucket near the pump.
  2. Boycedrilling
    Boycedrilling In the Trades
    Sep 30, 2013
    Royal City, WA
    No, it’s going to put out a bunch of water. Say you’re on a 40-60 pressure switch and you have a 75 psi relief valve. What’s going to cause the system to go to 75 psi? A welded pressure switch. It’s not going to shut down.
  4. banjo bud
    banjo bud Member
    Sep 24, 2018
    South Carolina
    Is that common?
  5. ThirdGenPump
    ThirdGenPump In the Trades
    Apr 8, 2016
    MA
    Depends on the size of the pump and potential for damage.
    On a regular domestic system it's rare to plumb the relief valve anywhere, it just gets aimed down in front of the pressure tank. logic is it's better it dumps water on the basement floor than blows up a random pipe in a wall somewhere. If the pump stays over pressure it will continue to dump water there.
    On larger systems I always hard pipe them outside, preferably to a location someone will notice.
  6. banjo bud
    banjo bud Member
    Sep 24, 2018
    South Carolina
    It’s a 1/2 HP shallow well pump.
  7. Boycedrilling
    Sep 30, 2013
    Royal City, WA
    Plumbing code says to plumb a relief valve to a floor drain or outside. Does that actually get done? Not very often.
  8. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    99% of the time you will get away with it. But the 1% that has a prv pop off will certainly not like the flood it causes.
Similar Threads: Plumbing pressure
Pumps and Tanks Well Forum & Blog. Water is life. Brass, SS, or PVC Pressure Tank Plumbing? Feb 28, 2018
Pumps and Tanks Well Forum & Blog. Water is life. Pressure tank plumbing May 14, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Insufficient volume/pressure - Well? Plumbing? Softener? Oct 5, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Pressure tank difficult plumbing Aug 31, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure low. Will a plumbing company be able to trouble shoot? Apr 14, 2013
