Plugging a 1/4 inch hole in PVC drain pipe under the sink.
Dr Dee
San Jose, CA
So, I installed a RO drinking water system yesterday under my sink. I did drill a 1/4” each hole in the drain pipe, and used a saddle to connect the RO drain rubbing.
This all works fine. But I realized I connected the saddle AFTER the p-trap, where it should probably be before.
So now I’m going have to move that saddle, and I have a quarter inch hole to plug.
What’s the easiest way to plug that hole ? It’s a 1.5” PVC pipe.
Just to be clear, is that hole in glued PVC, or is it white plastic that is not glued?
If glued PVC, you could cut a repair coupler (example: https://www.homedepot.com/p/NIBCO-1...epair-Coupling-Fitting-C4801RPHD112/100344271 ) in half long-ways, and glue it in place. Actually, if you could remove 48% and stretch the coupler to get it in place, that would be good. For glue, you could use epoxy, or you could use PVC primer and pvc glue. Apply force with tape etc while the glue hardens.
If in doubt, post a photo.
I am not a plumber.
WorthFlorida
Solutions
Orlando, Florida
If your p-trap is like this one with couplings, just buy a p-trap for a few dollars and replace the arm section. Place the RO drain line above the trap in the tail piece.
Dr Dee
San Jose, CA
I am not a plumber.
Yeah, it’s glued. You can see the saddle with the tubing in the picture.
That is ABS rather than PVC.
One way you could do it without it looking like a patch, is to cut the pipe just beyond the hole. Glue an ABS trap adapter there. Then use slip connection pieces and replace the trap. The slip parts are usually white, but not always. You can also use chrome-plated brass.
I am not saying that is the only good way, but I think it is what I would do. With slip parts, you could disassemble for cleaning.
Kreemoweet
Seattle. WA
Shoot, a hose clamp and a little piece of rubber will seal that hole. And will probably last the life of the building.
Cjlambert
Red-Seal Licensed Plumber
Toronto, Ontario, Canada
Unscrew the union on the trap.
Cut the pipe where you drilled your hole.
Cut ⅛” off the piece you just cut out.
Use ABS solvent to weld an 1-1/2” ABS coupling on the pipe stubbing out of the wall.
Weld the piece you cut out into the coupling, and retighten the union joint quickly before the weld sets.
Michael Young
North Carolina
FAST, EASY, WON'T LEAK, CHEAP. I guarantee it
Scotch 66 tape would probably do the job too.
Pull tight for most of the wraps, but make low-tension for the last wrap. Cut the end with scissors, rather than tear.
