Pipes relocation - Ontario
Discussion in 'Canadian Plumbing Code Questions' started by cli1010, Mar 3, 2021.
  1. cli1010
    cli1010 New Member
    Mar 3, 2021
    Ottawa, ON
    Hi everybody,
    I have a sliding door between my kitchen and living room and I am removing it, making the opening bigger to put two barn doors. After removing the wall I have the waste and water pipes that go to the bathroom upstairs and need to move them. Here is the picture of what I want to do. Is that something that is by the code and not causing future issues?
    In my picture the blue thick line is the new opening. The black line is where I want the waste pipe to go (it will be between the existing stud on the left and the new one that will be at the end of the opening) and the red lines where the two water pipes will go (they will be parallel with the stud vs currently parallel with the wall...reason is because in that opening there on the left of the stud there is the main heating pipe that goes upstairs so the spot is tight)
    Thank you
Similar Threads: Pipes relocation
Canadian Plumbing Code Questions water pipes below electrical panel Oct 6, 2014
Canadian Plumbing Code Questions need help. Can drain pipes be in an outside wall? Nov 12, 2013
Canadian Plumbing Code Questions Combining pipes in Basement plumbing May 10, 2013
Canadian Plumbing Code Questions Is my Laundry room drain relocation to Code in Alberta? Nov 29, 2012
