Before or after buying the house, I would get a go no-go gauge for crimps. If the go gauge did not slide over sufficiently from any side, I would re-crimp the accessible fittings. Crimp tools should be calibrated periodically , and the tool used here may not have been calibrated. Leakage does not seem too bad, so it seems it could be an acceptable risk to me, since the crimps you show seem pretty consistent and very small. In fact, there may have been leakage early, and it has entirely stopped. I would turn the well pressure switch down to maybe 30/50 psi, and adjust the precharge accordingly. If city water, I might turn the PRV pressure down to 40 psi. See time 0:39 for info on how to use a go no-go gauge.
If the crimps gauge to be correct, then the dezincification theory would seem to be the deal.
I am not a plumber, and I have not done any crimp pex. The F1960 expansion fittings with pex-A I have used have the advantage that you can't make a connection that initially looks good and does not leak, without it being good.
