I'm not saying to call Uponor. fitter30 in post #14 suggested it and Jeff H Young in post #15 seemed to think it was a great idea. Those fittings, pipe, and clamps are not Uponor which is why I said "I doubt they want any part of this". So I don't recommend calling Uponor but I suppose you could try to get a manufacturer label or part number off of a fitting, figure out who it is (which will be the impossible part), and call them about it. But I would point out that companies with this issue had to settle class action lawsuits so I doubt they are going to self-identify or fess up over the phone. Zurn really got in hot water over this issue (pun intended) so they might be a potential fitting manufacturer.
I'll repeat again, the only way you get certainty out of this is to have a metallurgist examine a fitting. That will tell you several things - which type of brass this is (yellow brass dezincifies, red brass doesn't), what compound the white residue is (typically the zinc pulled out of the fitting forms zinc compounds that clog the fitting on the inside), and the condition of the base brass metal. When the zinc is pulled from the brass, it leaves a porous hollow copper left behind that is weak. Removing the fitting will also give you an indication of how bad the corrosion is on the inside of the fitting and if it is blocking the pipe (ie how long do you have until one of these gives out or fully clogs a pipe). I would get a plumber to remove the fitting(s) so they can repair the pipe and carry any liability for the removal and repair part and then a metallurgist to examine the fitting to provide certainty over what is happening. This is probably going to cost several thousand dollars which pales in comparison to what you are going to pay for the house and the mess you could inherit with that.
This procedure would be the way to guarantee someone can't shit on the results and deny the problem doesn't exist. What does your attorney for the purchase say about this? you want it documented and incorporated into the sale so there is no question what the condition is, where responsibilities lie, and how it should get paid for/negotiated into the price. everything else is just bullshit arguments over the internet.
